Hello,
I am trying to make a reflow oven and have already made my first prototype for testing.
I can´t get my MAX6625 to read anything from the K type thermouple. I need help! On the datasheet it said that in order for the cold junction compensation to work the negative side of the thermocouple had to be connected to ground wich I did. When I meassure GND with an oscilloscope I get the negative thermocouple signal ofcourse. Will this make my MCU crazy?
Also I have some questions about the thermocouple wave form. Is it supposed to be this way? (see image).
Thank you!!
