I'm finishing the design on two bits of test gear for release later this year and I'm in a bit of dilemma about how to get juice into the units. In a nutshell, I'm trying to decide if I go with mains power (IEC socket) or an external DC adaptor, so here's a brief description - I think it's a finely balanced argument but I'm struggling to
P331 - component signature analyzer (like a Huntron Model 30)
USB port on back, sits on bench.
Extruded alloy case with metal front panel (170mm x 55mm x 90mm HWD)
Power consumption 5 to 20W. Isolated +/- supplies needed inside.
Go with IEC socket?
Internal toroidal transformer.
Voltage selector required (inside probably)
Front panel rocker power switch? Latching power push-button? Rear switch only (in IEC socket)? Soft power button on front?
Heat dissipation will probably require 40mm fan? Temperature control? Vents in front or rear (not possible in sides).
Case at earth. USB port shield at earth (probably).
Extra £15-20 on BOM compared with external brick.
Go with external brick?
External 12v 30W brick with universal input. 2.1mm centre+ or Kycon.
Case at bricks 0V. USB port 0V at bricks 0V (so in most instances, the USB port defines case earthing).
Fan not required (probably).
Internal fixed frequency, fixed duty cycle push-pull converter for isolated supplies - low noise.
The other project is similar (P328 - audio analyser) and is in a case twice the length and consumes up to 40W (60W toroidal or bigger brick) - so will probably get a fan.
I'm attracted to the brick PSU for it's lower cost, fanlessness and easier construction on the other hand I like the IEC socket as it feels a bit more professional. I want to give both products a family feel, so what I choose for one I kinda want to use on the other
