Hallo again people,
I am trying to build a step up dc/dc converter for my project using the MC34063 part. In my project I need two power rails.
I need a ground referenced 15+ V rail and a floating 15+V rail. The rails will be used to power 12V regulators, which in turn
will be used to power gate drivers for MOSFETs. Instead of having two separate topologies, I thought it would be much more
practical to use one. So, instead of an inductor, I thought that it would be nice to use a transformer, with the primary as the
step up inductor and the secondary for the isolated rail. I need the output transformer output rails to be over 15V after
rectification so that I am sure that the regulators work properly, I don´t really need a precision circuit.
Since the MC34063 works with a comparator, it will be skipping pulses. The problem with that is that the voltage on the isolated
side, might and probably will, drop, something that I really don´t want. So I thought that if the non-isolated side has more load
than the isolated side, it will probably work. The question is... Is my thought correct? If not, want should I do?
From some research, I found that LM25017 would be great for producing both an isolated and non-isolated rail, BUT it´s a step
down converter, with that being said, it´s pretty much useless, since I´ll be powering my system will 12V and I need more than 15V
at the output, and I really don´t want more circuitly (something like a step-up to make my originally 12V rail 24V volts for it to work).
Still, while reading through the datasheet, I understood that this concept can work.
And then my question about the transformer. I got some samples from Coilcraft for the transformers. The provide with the DCR value
and the maximum power rating. I dug a little bit around the site of Coilcraft and found in their F.A.Q. that the Irms can be found from
this formula: Power rating = Irms² x DCR. Am I right about this? I mean that I got some JA4650-BL. They have a power rating of 2W
and a DCR of ~0.122 Ohm. That means that the Irms = ~4A, right? I just want to be sure that the transformer is good for the task.
I don´t think that I will be drawing more than an average of 150mA - 200mA per rail.
Anyhow, these are my questions. I hope that I was able to clarify them as good as I can, but if in need of more details, I´ll be around
Thanks for your time and patience, in advance!
Best Regards, Lefteris
Greece
