Author Topic: ISO-TECH / GWINSTEK range - Oscilloscope Schematic  (Read 8032 times)
Offline gm0otbTopic starter
« on: September 16, 2011, 08:57:28 pm »
HI,
My first post.. Woohoo!
Just bought a ISO-TECH SRI658 from ebay, only had it on for 5 minutes and the trigger stopped working, apparently ISO-TECH is really GWINSTEK.
After locating a schematic diagram (nightmare), the thing was up and running in no time.
Thought I would make the Schematic available to anyone who needs it, just PM me, its too large to attach. :)
Ray.
Offline saturation
  • Doveryai, no proveryai
    • NIST
Re: ISO-TECH / GWINSTEK range - Oscilloscope Schematic
« Reply #1 on: September 16, 2011, 09:33:01 pm »
Welcome!  Was it something like this?
http://www.ebay.co.uk/itm/ISO-Tech-ISR-50-MHz-Dual-Trace-Oscilloscope-/170675519695
Glad you got it working, it looks worth repairing and fairly low cost.  What was wrong with it?
Best Wishes,
 Saturation
« Reply #2 on: September 16, 2011, 10:52:24 pm »
Exactly like that one.. lol
Received it and within no time the thing stopped triggering on "Auto" and "Manual", it would trigger on the "Ext" from the front panel,  the bloke I bought it from was excellent, great com's and offered to send manuals etc.
After chasing around the net for 2 days, found a diagram, the scope had popped a PNP transistor on the Trigger switch circuit , just before hitting the trigger amp section.  I was lucky, easy fix.
Happy days!
Offline saturation
    • NIST
« Reply #3 on: September 17, 2011, 12:47:45 pm »
Enjoy.  In electronics, I find most fixing is easy, the harder part is finding the defect or the replacement part.  That you got it quickly is excellent.
Happy days!
Best Wishes,
 Saturation
Offline ptp170
« Reply #4 on: June 18, 2013, 08:11:35 pm »
I know this is an incredibly long shot since the OP only has 10 posts since 2011 but if you have that manual or, even better, a photo of the location of the PNP transistor then I would love you all forever!
Just got hold of an ISR622 with exactly the same issue and it would be great if I could fix it!
Kind regards
Chris
« Last Edit: June 18, 2013, 08:47:25 pm by ptp170 »
Offline ptp170
« Reply #5 on: June 18, 2013, 08:56:43 pm »
Think I may be getting somewhere....
Downloaded the 'GOS_600G_60MHz.pdf' manual from this link.. http://www.eserviceinfo.com/index.php?what=search2&searchstring=GOS+523%2F623
.. am currently staring at the schematics on pages 16/17??
Anyone like to take a punt on which PNP could be the likely cause??
Kind regards
Chris
« Reply #6 on: June 19, 2013, 04:04:10 pm »
Most likely Q401/2 are faulty, as they are on the input and can get cooked easily. Replace as a matched pair with 2 matched to be close in gain at least, so use 10 and choose 2 in the middle of max and min gain. 2SA838B can be found at
http://pdf.datasheetcatalog.com/datasheet/panasonic/SJC00005BED.pdf
Nothing special other than being a PNP 30mA 20V usable to 200MHz.
Offline ptp170
« Reply #7 on: June 19, 2013, 08:24:18 pm »
Hi SeanB,
You are indeed correct.  Ray (the OP) kindly emailed the fix as I had also been eyeing up Q401/Q402.  I have replaced the two PNP's with a couple of generic ones I had lying around and IT WORKS!
I have ordered two 2N3906's as this was the recommended replacement with the slight caveat being the Base and Collector need to be swapped over so I will swap then out when they land on my doorstep.
Thank you to everyone and especially Ray for taking the time to email me back.
Kind regards
Chris
