First I must confess I'm not that familiar with power supply design (mostly using Recom and LDO's). That's why this design is a challenge.
Basically I'm looking for a way to create a variable voltage (or current?) using a switch-mode power supply.
The goal is to dim (over USB of course) multiple strips of 12V LED's up to 2 Amps. Without linear mosfets or direct PWM outputs.
As the first is easy, it has obvious drawbacks for small enclosures. The latter however, has less obvious drawbacks:
- Flickering, LED's are made to be fed DC, not AC.
- EMI, running high current PWM over long distance emits all kinds of trouble. Right now I have direct pwm output, and I can "hear" the pwm since the LED's are next to my speakers.
Currently my search for capable buck converters isn't successful. Some offer "tracking" options, yet this is designed for ramp-up usage, not for continuous usage.
Most of them use a feedback using a resistor divider. Which you can offset using an opamp. But you risk destabilizing it's control loop.
Some offer current limiting capabilities using a current output (to which you attach a resistor), you might be able to use a current mirror to control this.
I was initially looking for a smps with some kind of analog (0 to Vcc) or pwm input. Maybe a digital protocol.
Those seem to be limited to low voltage CPU and GPU power applications.
Does someone know of any chip or design related? Or a better approach?
Sidenote, the goal is to fit three channels into a 35x50x13mm pcb area. As it's looking now I'm in need of some huge inductors, and I'm not sure if it's going to fit.
