You can parallel as you wish, as long as each parallel branch is fused/protected separately.
+1 , because if you splice your circuit afterwards anyway, you would avoid not fusing properly in case one connection breaks. This means your distributor panel will have more than one supply, which is unusual and requires some effort to avoid problems (e.g. attention on RCD wiring), but is manageable.
Well, even in the lower portion, phases have incorrect sequence: First should be brown, then black, then gray. This different sequence (black-brown-gray) is I think only used in the capital city of Czechia
For Germany: Utilities can do it as they like, some connect houses in left hand rotating direction, some do right hand. Their terms and conditions apply. The only strict defined color is green/yellow for PE(+N) (unless wrapped with some different color tape to utilize it as something else). It is
recommended to not change wiring color within the system so the next guy looking at it won't be confused. The photo shows the interface between two systems, no big deal there, no laws broken.
