They are LLC resonant designs. You are asking to operate with 'step-up gain', which means it will probably be operating below the resonant frequency. May or may not be a problem, but it's a little different than modifying the output voltage on duty-cycle/PWM controlled topologies. Plus, you don't know how close they are running the synchronous MOSFETs to their max ratings, so on and so forth. I guess you accept these risks.
Anyway, I think there a potentiometer fitted on all of these by default, right?
Check the RPS-500/EPS-500 spec. For 18V, the adjustment range is just 17.1~18.9V (and maybe for reasons like the above). For 24V, the adjustment range is 22.8~25.2V. Sounds like you should start with the 24V as a base instead.
