Author Topic: LT3086 regulator -current boost  (Read 1090 times)
Offline IconicPCBTopic starter
« on: March 20, 2019, 12:03:41 am »
Are there any attempts to boost the current capability of LT3086?
If so are there any gotchas?
Re: LT3086 regulator -current boost
« Reply #2 on: March 20, 2019, 08:00:26 pm »
Thanks RES,
I am aware of parallel operation of the regulator.
I am thinking of an additional external current boost transistorso as to retain the nice features of the regulator but increase current from 2.something amps up to 50 amps.
Offline battmyrne216
« Reply #3 on: March 21, 2019, 03:15:59 am »
50 amps is crazy what are you trying to do? build a welder?
« Reply #4 on: March 21, 2019, 03:45:36 am »
Radio coms room... switch mode power supply is likely to affect the noise floor of the room.
It needs to be linear power supply.
