Author Topic: G \$\Omega\$ Input impedance Voltage measuring up to 1kV  (Read 1445 times)
Offline JesterTopic starter
« on: October 13, 2018, 12:58:20 am »
I was working on a circuit the other day that measures ac/dc voltage up to 1kV. The input impedance of the circuit is ~2M \$\Omega\$, so simply connecting any of my DMM's (10M \$\Omega\$ input impedance) loads the circuit considerably. I do have several 34401A's however the high impedance mode can only be enabled for low voltage ranges.
So perhaps I should build a high voltage, high input impedance circuit for the next time I need to make a similar measurement.
Can anyone point me to an appropriate app note?
« Last Edit: October 14, 2018, 01:28:27 am by Jester »
Online EEVblog
Re: G \$\Omega\$ Input impedance Voltage measuring up to 1kV
« Reply #1 on: October 13, 2018, 01:14:21 am »
https://www.eevblog.com/forum/projects/hi-z-high-voltage-probe/
A contact electrostatic voltmeter might do the business, maybe something like this
http://www.trekinc.com/products/esd_voltmeters.asp
Online joeqsmith
« Reply #2 on: October 13, 2018, 01:36:51 am »
My $50 multimeter goes off in the weeds whenever I start making even tiny sparks.
:-DD
« Reply #3 on: October 13, 2018, 08:24:22 pm »
I'm envisioning a circuit something like this:
R1,R2 are 1%, rated for 3kV working voltage
R5, R6 are to match the gain, I would hand pick them
Output drives 34401A, the 10G \$\Omega\$ input resistance mode only works on 10V and lower ranges, so this circuit would be used for V > 10V
OP07, is not great with lower input voltages, perhaps an alternate with lower input current OPA191?, suggestions?
Please critique and suggest ways to improve.
« Last Edit: October 13, 2018, 08:44:17 pm by Jester »
