I've been given a couple of old Weller PS-3D and associated irons.
One of the irons works but occasionally overheats, the 'stat is sticking.
I know I can clean and if necessary replace the stat (and I have a box of spares) but it occurs to me that it would be possible to monitor the operation of the thermostat and either sound an alarm or just turn off the iron if it sticks because, occasionally, I might leave the iron on for a period of time and only notice it's stuck after it's been overheating for a while.
I'm sure it would be possible with some very simple electronics (bubblegum 555 comes to mind) but a PIC costs way less than a quid and would be a fun thing to do.
So, I'm thinking monitor the power up from cold, reset a timer the first time the current stops flowing or switch off the current if it overflows and signal failure.
Once the initial warmup period has expired, use a shorter interval timer and, again, reset it when current stops flowing or turn off current and indicate failure if it overflows.
Reset of the alarm would be as simple as power cycling the PS-3D.
other than the obvious 'fit a new stat you tightwad' can you think of any features or snags?
How would you monitor the current drawn? (I'm thinking either one of the dirt cheap eBay current sensor breakouts or a hall effect device with a few turns of wire wrapped around it or an old school sense resistor)
