Thanks hero999.
Yes the cable is a flexible copper cable of 9mm diameter. From the table I can see that there several properties of it. But what does the 0.0175 mean in the formula ?
Www.Georgehobby.wordpress.com
Equipments: DSO104z, Hakko FX888D
It looks similar to the figure for given for annealed copper, with the decimal point in a different place.
The formula is confusing. It says cable diameter, given in mm
2, which makes no sense. Diameter is measured in mm. Cross-sectional area is measured in mm
2.
I'd use the figure from the table 1.72×10
-8Ohm×m
2, which gives the resistance of a cube of copper 1x1x1m. 1mm
2 = 1×10
6m
2, so the resistance of a 1m length of 1mm
2 copper is 1.72×10
-2Ohms.
Now if you know the cross-sectional area of the cable, which can be calculated from the diameter, area = pi(
1/
2d)
2, you can work out the resistance, then the current given by a certain voltage drop, using Ohm's law.
