Is there any easy way (preferably a simple app) to capture and store data from a device plugged into the USB OTG port on an Android tablet? The app doesn't need to understand the data, just store it as it arrives. The data is 8-bit binary.
I have configured a uBlox LEA-6T GPS module to output ubx raw data on its USB port. I want to capture this data for later post processing with RTKLIB. I'm doing it right now with STRSVR from RTKLIB on Win7. I'd like to use a tablet so I can go portable.
It just occurred to me - would a driver for the uBlox GPS be needed, or does Android see it as a Com port if I am simply capturing the incoming data? I know on Win7, to use the uCenter software, a driver is required. The GPS will start spewing data as soon as it is plugged into a powered USB port.
I know that I could use Bluetooth and that Android has SPP support, which might make things easier. However, I don't have a Bluetooth enabled GPS, or a Bluetooth module that I could interface with the uBlox GPS I do have. I could always order something, but If I can make this work with what I already have, that would be preferred.
All I need is a simple app that has a START and a STOP button. Every time START is pressed, a new file is created and any data coming into the USB port is saved. When STOP is pressed, that file is closed. Pressing START again will open a new file. I don't care whether the data is saved to internal storage or an SD card, although having a choice would be nice.
I've done some searching on the net, but haven't turned up anything so far. Thanks for any help.
