Nice work on the "Lab Supply"
What do you need for voltage and current for the higher power supply?
Agree, for lab use you want a fully isolated output and the ability to have 0 volts output.
Maybe a good SMPS like the Mean-Well types with a post linear output regulator for CV and CC?
One idea that I've not tired is to "float" the isolated MW output negative return from the output negative return with a pair of back to back high current diodes. This would allow a small negative voltage relative to the output return to allow "zero volts" at the output, and also handle to output currents. The CV and CC control loops would be referenced to the return outputs and not the MW return. Could be issues and allow Murphy to step in, so maybe some good prior simulations and testing required.
Also, some of the linear Op-Amp type power devices might prove useful, like the LM3866, LM1875, and APEX devices for example.
Anyway, sounds like a fun project, please keep us posted on your progress.
Best,
