Author Topic: Measuring standby power  (Read 37470 times)
Offline rr100Topic starter
« on: March 26, 2014, 09:05:34 am »
Measuring the standby power on AC mains devices is not as easy as it sounds and many consumer devices (Kill-A-Watt types but also just using an ammeter in series with the load) give a value that is much higher than in reality, sometimes with more than an order of magnitude.
What would be a proper way to measure this without a dedicated equipment? I don't need ultimate precision, even 30% off would be ok.
Probably the ultimate would be to just measure the current (over a series shunt) with a scope while triggering from the mains but I can't say I particularly like this idea (both because you need to probably write a program to get you the result from the resulting waveform and also because of the safety issues, although you probably can get away by using a transformer to isolate the scope from the shunt you try to measure).
Any other ideas?
Offline TriodeTiger
Re: Measuring standby power
« Reply #1 on: March 26, 2014, 09:11:53 am »
I know nearly nothing, but..
A current transformer? I'd assume the average power could be found through the average current, and the average current remains a constant while in standby. Find the peak through a peak detector, and multiply by the RMS voltage of course.
"Yes, I have deliberately traded off robustness for the sake of having knobs." - Dave Jones.
Offline tszaboo
« Reply #2 on: March 26, 2014, 09:18:04 am »
There are analog front ends to measure mains power consumption. I was using something like the ADE7768 to do this once upon a time. It is really easy, you just put a shunt on the mains, and also divide it so the IC can measure it. The output is pulsed, so you only need an optocoupler and an universal counter on the "safe side" to do accurate measurements. Of course if you dont have a counter, you can put together any digital logic counter, Arduino or whatever, you only have one LED which will blink every now and then depending on the consumption.
I guess I dont have to mention to be careful if you design something like this, use proper layout, protect your inputs and your life etc...
« Reply #3 on: March 26, 2014, 09:21:50 am »
TriodeTiger: NO, this is precisely the pitfall I try to avoid. You can't assume much with these black-box power supplies and the peak method can give you EASILY 200W for something that takes basically nothing. A "true-RMS" ammeter would do better but still can show considerably more than real.
That ADE sounds certainly promising.
Offline NiHaoMike
    • Facebook Page
« Reply #4 on: March 26, 2014, 03:48:59 pm »
Use an isolation transformer, a DSO, and a relatively high value shunt resistor.
Offline djacobow
  • takin' it apart since the 70's
« Reply #5 on: March 26, 2014, 06:56:39 pm »
You might want to check out this thread:
https://www.eevblog.com/forum/testgear/yokogawa-cw-10/
I originally posted about wanting to measure standby power on a budget. It is not easy.
There are a handful of < $500 devices that can do the job, but really, anything quality is north  of $2k.
One of the more intriguing suggestions, which I have yet to try is to modify a Kill-A-Watt by removing the 2mOhm (or so) current shunt and replacing it with a 200 mOhm (or so) current shunt. Device should read approximiately 100x more sensitive than it is. Obviously, you don't want to plug something that draws 15 A into it after modification, but it should be good for generating low power measurements. Probably very inaccurate, but better than nothing.
« Reply #6 on: March 26, 2014, 09:35:47 pm »
As I said I want something that can be even 30% off, but I don't want to be order(s) of magnitude off (well, up to a point, I have no problem if 0.0001W is shown as 0 or 0.1W).
Any caveats with the Kill-A-Watt mod? Not safety-wise but I'm thinking these switched power supplies really don't behave as any theoretical nice inductive (for example) load so what is the Kill-A-Watt doing, is it actually sampling the current many times while minding where the voltage is in the cycle or something much simpler just assuming some specific waveform for the current?
Offline tszaboo
« Reply #7 on: March 26, 2014, 09:49:29 pm »
If you check the IC mentioned by me, that ie samples at 450Khz. After the inductive filtering of a cable you can pretty much see any spikes caused by any switching supply.
Offline NiHaoMike
    • Facebook Page
« Reply #8 on: March 26, 2014, 11:25:27 pm »
You can add a pair of inverse parallel diodes for overload protection. Then it might be good for checking standby draw of a device that initially draws a lot of current.
Offline The Electrician
« Reply #9 on: March 27, 2014, 06:33:09 am »
I did some more measurements on the modified Kill-a-Watt mentioned in the referenced thread.
First, I measured an LED light bulb with the modified Kill-a-Watt, and also with the power measurement application on my Tek scope.  Here's the scope capture of the measurement.  The green trace is line voltage, purple is bulb current, and the red trace is instantaneous power.  The modified Kill-a-Watt measured 5.97 watts:
Next I measured the no-load power consumption of a small switcher wall wart (it's the charger for my electric razor) without a load.  The power consumption is very small and as can be seen from the scope capture, the current waveform has a very high crest factor.  The modified Kill-a-Watt measured .067 watts, 1.5 mA current draw, and .178 VA:
The modified Kill-a-Watt is doing a good job of measuring the true power with these quite non-sinusoidal current waveforms.  It reads a little low but I'm not going to bother trying to trim the .2 ohm shunt; I just mentally increase the reading by about 2%.
« Last Edit: March 27, 2014, 06:37:57 am by The Electrician »
The following users thanked this post: rs38
« Reply #10 on: March 27, 2014, 11:11:09 am »
ADE7768 sounds like the way to go here; also cheap and probably they'll even send free samples but the pitch seems to be outside my comfort zone for a "quick one". However I would consider it for any dirt cheap integrated solution (-> serial, bluetooth, etc). Any idea where to find the evaluation board (or some other similar product, because they mention it in the datasheet but is nowhere to be found)?
Other than that I REALLY appreciate the Kill-A-Watt idea AND the research with the scope, many thanks! I only have the Rigol DS1052E that can do Math AxB but I can't seem to find a way to average that in the Rigol (to get the power). So I'll have to just guesstimate or go through the computer somehow.
Now let's see where to find a cheap "kill-a-watt" clone (I'm in Europe so I'll have to settle for something else and see for myself how it works).
Offline djacobow
« Reply #11 on: March 27, 2014, 11:33:14 pm »
Yup. I haven´t cracked mine open yet. When I do I´ll see if diodes like that are already there. I mean, they need to protect from spikes anyway.
Offline NiHaoMike
    • Facebook Page
« Reply #12 on: March 27, 2014, 11:47:38 pm »
There aren't any since the original shunt can take a very large amount of current without overheating (a PCB trace would probably fail first!), but a 0R2 would not be as robust.
I just modified one of mine with a 0R2, but also put in a switch to change between 100x and 1x (original) mode. In 1x mode, the 0R2 is bypassed and the input routed to the original shunt. In 100x mode, the 0R2 is enabled (with a pair of Schottky diodes in inverse parallel to handle overloads) and the input routed to that shunt.
Offline mjkuwp
  • mechanical engineering defector
    • The Mz Lab
« Reply #13 on: March 28, 2014, 01:45:13 am »
What level of standby power are you talking?  What makes you say that meters are an order of magnitude off?   how do you know the error exists?
You can use the eevblog uCurrent ! and a DMM if the load is really low and you take the necessary precautions. - that will give you the current and depending how you do the grounding it seems you could get that signal to a scope.
Offline NiHaoMike
    • Facebook Page
« Reply #14 on: March 28, 2014, 05:00:28 am »
The uCurrent is designed for low voltage use (low insertion resistance) and would be easily damaged by current spikes (e.g. charging of the capacitors in a switching supply). In addition, the insertion resistance of a common multimeter is already insignificant for low current mains, but that won't help as AC power measurement requires reading both voltage and current and vector multiplying the values.
« Reply #15 on: March 28, 2014, 08:37:13 am »
I am talking about the standby for totally normal devices from media players to TVs and maybe even wall-warts, something like 0.1-5W maybe.
Please take a look at the second scope capture/picture. There is no way to read a good power value based on measuring the current without sampling the voltage the very same instant (for the very simple reason that the voltage isn't constant). The usual ways to still do it (as in measure the power with the ampermeter) are:
- take the peak value and assume that's good for the average, divide it (I think) by sqrt(2) and multiply by Vrms. This would give in this case a huge value of power compared with the actual (because the peak is short)
- take the RMS value of the current and multiply by Vrms. This would give here a somehow lower value compared to actual because the peak current (and most current and power consumption in fact) is at peak voltage, not at average. However, if for some reason the peak current is when the voltage is really low there is no limit at how much we would OVERestimate the actual power
The uCurrent is absolutely not needed and is extremely poorly suited for this application. The uCurrent isn't mainly solving the problem of measuring low currents (that's trivial, just use a big enough resistor as a shunt), instead is solving the problem of actually having some voltage to measure if you want enough resolution. Having a 0.5V drop across a shunt might be a problem when analyze a device powered by a 1.2V NiMh but is absolutely of no importance for something powered by mains. In this case the uCurrent can be fully replaced by a simple resistor. In fact the resistor is much safer, simpler and has almost infinite bandwidth.
Offline mjkuwp
    • The Mz Lab
« Reply #16 on: March 28, 2014, 11:25:42 am »
afraid there is a bit of misunderstanding due to assumptions I made, sorry.  I agree with your points and understand them except I don't agree the uCurrent is poorly suited...
As you said, one must sample V and I at the same time at a high rate and multiply them together.  Digital scopes will do this so I guess the questions was more around how to make the connections.  I am building a power meter mostly for hobby and  have used the uCurrent to calibrate the I RMS portion of the meter.  I use a 4-terminal shunt resistor in my design.  The chip ADE7953 is used for all the calculations.  There are other energy metering chips that you could use.
I think the idea of using the Kill-A-Watt with a different shunt resistor value is a really good one if you find a way to bypass the current around the meter when the device is not in standby.
...there are many ways - it all depends whether you are trying to get one measurement, or design a product, or do this for your own education, etc..
Offline dannyf
« Reply #17 on: March 28, 2014, 11:36:22 am »
That is generally true, and need a fairly fast adc as well.
Some mcus have two independent adc modules so that can be done.
An alternative, using one adc, is to perform sequential but alternating samples (volt->current->volt->current...), relative to the zero-crossing point. Once you have enough data points accumulated, you can realign them in software.
Offline macboy
« Reply #18 on: March 28, 2014, 12:05:12 pm »
A True RMS ammeter can help give you a quite accurate view of the VA (apparent power) but not of the Watts (real power). You pay for Watt-hours, not VA-hours. Inductive or capacitive loads use more VA than W, which means that the power factor is not 100%, i.e. means current is out of phase with voltage.  Using separate RMS ammeter and RMS voltmeter will only tell you VA, not W. You need a wattmeter that can internally multiply the instantaneous voltage and current waveforms, and average the result.
Offline HackedFridgeMagnet
« Reply #19 on: March 28, 2014, 12:07:47 pm »
An mcp3901 ic can do this, obviously quite a bit of work involved though.
« Reply #20 on: March 28, 2014, 12:28:57 pm »
Can you please find at least one single reason why you would use a uCurrent and not a resistor?
Offline mjkuwp
    • The Mz Lab
« Reply #21 on: March 28, 2014, 12:56:24 pm »
a resistor is fine.
Just that I happened to have the uCurrent Gold on my desk and it has the banana jacks on it.  My DMM has banana jacks on it so it is an easy fit.   I have a BNC to Banana jack adapter for my scope.  I don't have a sense resistor other than the ones soldered into my circuit.
« Reply #22 on: March 28, 2014, 01:19:14 pm »
I saw this one referenced in another forum:
http://www.lowenergysupermarket.com/collections/energy-monitors/products/plug-in-energy-monitor
Offline Mr. Coffee
« Reply #23 on: March 28, 2014, 01:45:45 pm »
Many Kill-a-Watt types are just an ammeter assuming a P.F. of 1, but the actual Kill-a-Watt brand model that I have truly measures wattage on inductive loads. I cannot say how accurate it is on non linear loads like switching power supplies or other high harmonic developing equipment.
Offline NiHaoMike
    • Facebook Page
« Reply #24 on: March 28, 2014, 01:54:31 pm »
The Kill-a-Watt is regarded as very accurate for what it does, more than good enough for checking and optimizing energy use at home.
