Author Topic: Anyone know of a Buck Equivilent to a NCP1402?  (Read 769 times)
Offline TheRuler8510
  • RF Engineer
« on: August 28, 2014, 03:20:02 am »
Digikey does not allow you to search for lowest quiescent current. So what I really need is a very low quiescent Buck converter that will switch input voltage in the range of 6-10V down to 3.3V.
The NCP1402 is a nice Boost converter with 1 uA of off-state leakage current, which I guess is the same as quiescent.
Thanks,
"There are no facts, only interpretations."
--Friederich Nietzsche
