Author Topic: choosing a transistor  (Read 1310 times)
Offline kjn4685
« on: August 28, 2014, 02:46:49 am »
I would like to know if I had a transistor with 50 vcbo and another with the vcbo 100 vcbo will work. The veco is 120v
« Last Edit: August 28, 2014, 02:51:10 am by kjn4685 »
Offline TheRuler8510
  • RF Engineer
Re: choosing a transistor
« Reply #1 on: August 28, 2014, 03:22:29 am »
You need to look at other parameters like hfe.
What is the application? Everything depends on that.
"There are no facts, only interpretations."
--Friederich Nietzsche
Offline Mike Warren
    • Personal Website
« Reply #2 on: August 28, 2014, 03:23:47 am »
If all other specs are the same, then yes, but I doubt that would be the case.  Other than that, compatibility is largely dependent on the application.
Can you post what the 2 transistors are and what its use is?
Offline David Hess
  • DavidH
« Reply #3 on: August 28, 2014, 04:52:32 am »
Are you sure you did not get those reversed?  I have never seen a transistor where the Vceo was greater than the Vcbo.
Except in very specialized applications like avalanche mode switching, increasing the Vcbo will not affect circuit operation although higher voltage transistors are often slower or have lower gain.
