Author Topic: Mega problem with resistors  (Read 1555 times)
Offline PerranOakTopic starter
« on: July 15, 2020, 04:57:47 pm »
Recently, while dealing with oscillators, I realised that I only have 1MOhm resistors at this high value.
I've looked into getting a few in the MOhm range: 1.5, 2.2, 3.3, 4.7, 6.8, 10 but buying them separately is a pain and pricey.
Does anyone know of a convenient batch of assorted resistors of this high value anywhere ... even eBay?
Cheers.
You can release yourself but the only way to go is down!
RJD
Offline themadhippy
Re: Mega problem with resistors
« Reply #1 on: July 15, 2020, 05:07:22 pm »
try cpc,around a quid for 100 of each value
Offline OM222O
« Reply #2 on: July 15, 2020, 06:58:30 pm »
Mouser, digikey, rs components, all have them for cheap. Even a reel of 2500 won't be "pricy" for the volume.
Offline Vovk_Z
  • Country: ua
« Reply #3 on: July 15, 2020, 11:10:20 pm »
I bought mine on eBay. They are good enough. Google for "Resistor kit". Look for 2000 pcs or more.
For example, metal film, through-hole.
And, if you need SMD/SMT, then Here it is, 0805. - I got 0805 and 1206 book kits. Those book kits are very convenient.
Unlike semiconductors we may buy resistors from China surely.  :-+
« Last Edit: July 15, 2020, 11:17:04 pm by Vovk_Z »
Online ledtester
« Reply #4 on: July 16, 2020, 01:43:17 am »
But the OP wants values > 1 Mohm.
I've run into the same problem - I think there is a niche market for high-resistance resistor packs.
Offline Alex Eisenhut
  • Place text here.
« Reply #5 on: July 16, 2020, 01:50:40 am »
For sure! High value resistors are more of a vacuum-tube era thing...
« Reply #6 on: July 16, 2020, 02:52:47 pm »
Cheers all.
RJD
Offline golden_labels
« Reply #7 on: July 16, 2020, 03:30:02 pm »
If you have limited budget and hobbyist projects are on your mind, I would simply skip some values and compose them from lower resistances. You do not need 2.2MΩ, you can use 2× 1MΩ. This way you can buy in 100s. If you are not constrained by space or having specific requirements about inductance, I see little reason to have exact-valued resistors. Even in professional setup it may be better for BOM optimization to go for some common values.
I don’t know how shipping looks like after Brexit, but you may look at what TME offers: 1/4W carbon THTs start at 0.70 GBP/100pcs, 1/2W metal film THTs start at 2.68 GBP/100pcs.
You may also find some fellow hobbyists locally, order larger quantity of various values and split the costs.
« Last Edit: July 16, 2020, 03:32:12 pm by golden_labels »
People imagine AI as T1000. What we got so far is glorified T9.
Offline tooki
« Reply #8 on: July 16, 2020, 04:42:41 pm »
Cheers.
Why not just add a few to your next Digi-Key/Mouser/Farnell order? They don’t cost that much...
Offline Kirr
  • Country: jp
« Reply #9 on: July 17, 2020, 08:16:25 am »
This:
+ this: http://kirr.homeunix.org/electronics/resistor-network-finder/
Can get you quite far, especially for a hobby project.
Offline exe
  • self-educated hobbyist
« Reply #10 on: July 17, 2020, 08:51:54 am »
I just buy kits like this: https://www.aliexpress.com/item/32370322093.html . I have 0805, 0603 and TH 1/4W kits. I wouldn't use them in precise circuits, but for general stuff they work great. Just don't forget to measure the actual value smd tweezers before use (just in case, never got wrong value in my kits, but sometime I read smd code incorrectly).
Online ledtester
« Reply #11 on: July 17, 2020, 10:08:14 am »
Some aliexpress/ebay vendors are eager to get your business and are willing to try to source special orders, so you might just ask around.
Might not make sense in this case, but something to keep in mind.
« Reply #12 on: July 17, 2020, 10:22:54 am »
Fantastic advice all, thank you.
RJD
