Author Topic: Memory - die pictures  (Read 26640 times)
Offline NoopyTopic starter
    • Richis-Lab
Re: Memory - die pictures
« Reply #75 on: September 04, 2026, 03:11:12 am »
If you remove the upper layers, you can get an unobstructed view of the substrate and, thus, of the active areas.
This image is also available in a higher resolution: https://www.richis-lab.de/images/RAM/22x11XL.jpg (128MB)
Outside the memory area, the transistors have a very simple geometric structure. In the memory area, the structures have been optimized so that the memory cells take up as little area as possible.
https://www.richis-lab.de/RAM19.htm#sub
 :-/O
The following users thanked this post: RoGeorge, D Straney
