Author Topic: Proper way to dry boards?  (Read 5658 times)
Offline reagleTopic starter
    • KuzyaTech
« on: May 24, 2011, 02:16:01 am »
Here is a questions for those building things at home- how do you dry boards after sodlering and washing them?
I know how it's done in the industry- compressed air or special board washer/dryer systems, but what do you do at home?
Suppose I use solder with water soluble flux, I wash the boards, they are nice and clean. If I just let them dry, I'll have all kinds of mineral deposits on them. I suppose, rinse with de-ionized/distilled water might help?
Other options  I know of are to use rosin core solder but that can still chew up copper after a while, or a no-clean one, if it will never get wet
« Last Edit: May 24, 2011, 02:41:51 am by reagle »
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
Re: Proper way to dry boards?
« Reply #1 on: May 24, 2011, 02:32:03 am »
I had never ever use water ..
Only purified not colored alcohol.
And it dry's in seconds by it self.
Its very expensive , but worth's it.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #2 on: May 24, 2011, 03:12:56 am »
if you want the proper way, its the same thing as in the industry, except on the small scale and diy level ;) compressed air is the easiest. if you can buy $300 ee stuff, sure you can also get one cheapo compressor w acc.
Offline Zero999
  • 0999
« Reply #3 on: May 24, 2011, 05:32:35 pm »
I've always used soap and water, rinsed in clean water and dried with a hair dyer
Where I used to work, we rinsed with distilled water and dried with a heat gun set to low temperature.
Offline johnmx
  • Country: pt
« Reply #4 on: May 24, 2011, 10:03:15 pm »
I use acetone or flux remover like this one:
http://pt.farnell.com/chemtronics/es835be/cleaner-flux-off-200ml/dp/860414?Ntt=ES835BE
Then I apply some spray varnish (e.g. Plastik 70 from Kontakt Chemie).
Be careful with the water, some components don’t like it (e.g. relays).
Best regards,
johnmx
Offline Kiriakos-GR
  • Country: gr
  • User is banned.
« Reply #5 on: May 24, 2011, 10:53:57 pm »
I love that stuff , many years back I was making some control panels.
I use to paint the aluminum face , plus adding letters set on it as labels  , and then some spray varnish " Plastik 70 " for protection.
But the smell of it, before it gets dry , it can kill a horse ..     :)
Offline johnmx
  • Country: pt
« Reply #6 on: May 24, 2011, 11:13:16 pm »
I like that smell… and also the smell of diluent and gasoline :D
Best regards,
johnmx
    • KuzyaTech
« Reply #7 on: May 25, 2011, 12:04:48 am »
Hey, trying to stay safe for a home use here :)
Offline vk6zgo
« Reply #8 on: May 26, 2011, 03:20:39 am »
Alcohol is good,I've used both surgical alcohol & the stuff we call Methylated spirits in Australia.
The "Metho" does leave a white deposit,but it is fairly harmless,& if you use paper towels, Kimwipes or similar,you can wipe it off as you go.
There is a product that RS Components sell in Aust,& probably the UK that comes in a  pressure can & looks like
shaving cream. This is very effective,we used to spray it on,wait about 10 minutes & wash it off with water.
We started off with Distilled Water,but after a while,we went with plain tap water with less critical circuits.
We would then dry with compressed air, followed by a heat gun.It gets pretty hot in the summer here,so just leaving them out in the sun is another option.
We did not experience any increase in failure rate using this method.
Obviously,everybody wants to send their boards out in pristine condition,but you can go overboard with worry about "contamination". If you look at boards in service in industry,they will work OK,even with the most horrendous contamination due to the enviroment in which they operate.
Even in fairly benign environments such as TV Studios,there was an amazing amount of crud on the boards.
One warning about water use,if you have things like IF cans,etc,these things are only shielded for RF,they are not watertight.
Most of the PCBs you will encounter will not use such devices,although maybe getting water & crud under large ICs might not be good.
VK6ZGO
« Last Edit: May 26, 2011, 03:25:05 am by vk6zgo »
Offline Zad
    • Digital Wizardry, Analogue Alchemy, Software Sorcery
« Reply #9 on: May 26, 2011, 06:07:02 pm »
Be extremely careful if you have any skeleton or trim-pots on the board. Some carbon traces can absorb liquid, and any invisible residue on the track can lead to the potentiometer wiper going open circuit.
    • KuzyaTech
« Reply #10 on: May 26, 2011, 06:46:00 pm »
Good point. Same with wires- they tend to wick moisture in and then corrode later on.
Offline IanJ
  • Country: scotland
    • IanJohnston.com
« Reply #11 on: June 03, 2011, 02:14:33 pm »
Back in the day we used Freon in our ultrasonic cleaner and it evaporated in seconds afrer removing it from the tub.
But nowadays we have to use distilled water to wash off the flux cleaner.........and we dry our boards using a heat gun a good distance away with the boards on a stand sitting vertically. Each side about 30mins then leave the board overnight before even thinking about powering up.
Ian.
Website: www.ianjohnston.com
