I have also managed to get it to work in Wine, just the 32bit version sometimes glitches and doesn't react to clicks, only keyboard. Weird bug.
I am not sure whether the UI is "better" than LTSpice, though - it does have its own share of quirks, such as each component having 8 (!) predefined orientations you select from instead of a "Rotate" and "Mirror" functions but I guess one can live with that. The way how to define probing points for plotting is a bit clunky, though - LTSpice allows to place probes, here you have to define the plots by hand in a table. Or maybe I haven't figured it out yet.
I love some of the features such as the power analysis - you get a nice "HOT!" warning on a transistor if there is too much current flowing through, "LIN" when in linear regime, etc. Not absolutely necessary but neat.
I hope that component models will be available (or adaptable) for it, though - that's where LTSpice has definitely an advantage.
