Have recently purchased a cctv nvr and cameras. I have 2 unused Poe ports. My idea was Can i split the feed , data and power so that the same camera can be plugged into 2 Poe ports at the same time. the result hopefully being 2 channels running the same image. Why you ask? I want to set up each channels with different parameters and motion areas.
One idea was to use 3 lengths of cat 5e or 6 cable in a "Y" put rj45 plugs on the ends. Would the two power inputs to the camera be a problem, and the data split. The nvr is a swann nvr8 7090 with 8 separate Poe ports.
Has anyone done something similar, better ideas greatly welcomed.
