Hi Everyone.
I want to be able to display a negative voltage in a panel meter for convenience, but from the one page data sheet of the CX101B I cant tell if I can simply feed a negative voltage into it just as I would into a multi-meter. I was going to buy one and try, but, why blow it up if it turns out it doesn't work like that.
cheers
kvresto.
