Hello,
I am building a bench power supply and I am using +/- 15V auxiliary supply for the high side control circuitry. That aux supply is based on LM317/337.
As I am finalizing the project it turned out that were are random spikes from the main supply when I turn it on because of the aux supply - in order to fix that I need to delay the +15V rail by 100-200ms relative to the -15V rail.
Any ideas how to do that without going digital ?
