I would be more impressed with the assignment if it involved an analytical or computational approach to derive the formulas from theory, and/or actual experimental tests involving fabricated boards of various geometry (assuming of course you have access to the VNA fast enough and accurate enough to perform the requisite tests).
Neither of which sounds like "short essay" material. Indeed, masters' theses have been written on less. So...
On the plus side, for such a, well, weak paper -- on an otherwise rather advanced and involved topic -- whether your conclusion is ultimately correct or not, probably won't matter very much, just as long as you've presented your case clearly from thesis to conclusion, based upon the references used to inform that conclusion. Or to put it slightly differently: even if you use shitty references, as long as your conclusion is right, it's only partially your fault (choice of reference, or failure to sufficiently research the subject, is still your fault, but it's not usually as big a part as doing the writing itself).
