Author Topic: Mini Din adventure ..  (Read 2662 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: May 13, 2010, 07:45:11 pm »
I had planed to extent the TTL flash cable for my Olympus camera - external flash.
And I like to share my odyssey ,  yes I had one ..  ;)
First of all I got  several male Mini Din , with wrong in diameter center plastic pin,
some one had flood the market with damn cheap bad made, male ones.
As soon I found one good set of three males , I was able to move on..
At the process  of soldering , I killed the first male Mini Din , due high temperature at the soldering station.
No one ever advices , how much temperature to use ,
when you work with those small and sensitive plugs !!
The best tip that I have to offer , are to have the male & female hooked together, when you solder the cables on it.
About how to correctly lock the small metal clip on the cable ( anchor )  ,
its best to install the metal clip in the hole of the plastic inner body first, then to put above the cable with the soldered plug , and to use an common plier, and press the plastic bottom with its end of the metal clip.
It gets a nice curved shape that way.
Pictures ..
  • Country: gr
  • User is banned.
Re: Mini Din adventure ..
« Reply #1 on: May 13, 2010, 07:46:10 pm »
Part No2
