Author Topic: RD DPS5015 (50V/15A ) and DPS5020 (50v/20A) digital power supply rippple test  (Read 6177 times)
Offline RD Tech
  • Banned!
  • Country: cn
This is ripple test for DPS5015 .
https://www.youtube.com/watch?v=QbcLtOT1IAQ&feature=youtu.be
Product page: https://www.aliexpress.com/item/RD-DPS5015-Constant-Voltage-current-Step-down-Programmable-digital-Power-Supply-buck-Voltage-converter-color-LCD/32702714880.html
upper competer page: https://www.mediafire.com/folder/3iogirsx1s0vp/DPS_communication_upper_computer
The required instruments and requirements for test :
Oscilloscope ? Probe *1, IT6721 power supply 58V +, 20M bandwidth limitation.
Oscilloscope Vertical resolution 50mV , Controling DPS5015 by the upper computer.
we are *1 probe test , VPP is about 100mV,
we also use *10 proble to test , but *10 Probe can cause extra interference to make measurement VPP higher .
we also make ripple test for DPS5020. https://youtu.be/i62bFRMdgPw
DPS5020 page : https://www.aliexpress.com/store/product/RD-DPS5020-Constant-Voltage-current-Step-down-communication-digital-Power-Supply-buck-Voltage-converter-LCD-voltmeter/923042_32821185351.html?spm=2114.10010108.1000023.29.Up1mtg
« Last Edit: August 01, 2017, 05:32:48 pm by RD Tech »
Offline floobydust
Re: RD DPS5015 digital power supply rippple test 50v15A
« Reply #1 on: August 01, 2017, 02:56:39 am »
That is pretty quiet  :)  No extra output filter needed. Nice.
I see 50mVpp no-load and 75mVpp at 3-10A, and 100mVpp at 15A, f=90kHz (I believe but not sure).
Ordered a DPS3005 (30V 5A) and look forward to trying it out.
The communication -C option with USB and Bluetooth boards looks very good. I should have ordered it.
It might be possible to make voltage waveforms, ramp,  pulse with the PC software?
The following users thanked this post: RD Tech
Offline alm
« Reply #2 on: August 01, 2017, 03:55:21 am »
Your links do not work: the part after the ellipsis (...) is missing.
Offline floobydust
« Reply #3 on: August 01, 2017, 03:59:35 am »
Mods, suggest merging this thread with this one about the DPS5015:
https://www.eevblog.com/forum/testgear/testreview-of-power-supply-frontend-dps5015-50v15a/
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #4 on: August 01, 2017, 05:23:10 pm »
the result will be different for different test device.
did you buy communication version? if yes, you can show your test result
about the voltage wave , I don't know what you want to do. you can try
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #5 on: August 01, 2017, 05:29:21 pm »
sorry, it is some mistakes, I fixed it , you can check it again
Offline RD Tech
  • Banned!
  • Country: cn
« Reply #6 on: August 01, 2017, 05:31:09 pm »
yes, this is our friends test too
because many friend need ripple test , but we don't have much time ,. so we only a video for riplle
it should be very clear
