Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Is the CRSDV signal required for RMII ethernet?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Is the CRSDV signal required for RMII ethernet? (Read 1071 times)
sswift
Contributor
Country:
on:
September 29, 2017, 07:19:45 pm »
Nevermind! It appears the SAMD51 doesn't support ethernet at all. The datasheet in question covers both SAMD and SAME and the SAME is the ethernet model that only comes in larger packages.
Last Edit: October 04, 2017, 07:14:08 pm by sswift
Logged
The Neutrino: A tiny 32bit Arduino Zero compatible!
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
