Author Topic: How can I see sound on an oscilloscope with a microphone?  (Read 27596 times)
Offline alank2Topic starter
« on: March 30, 2014, 11:40:26 pm »
Hi Everyone,
I'd like to see sound waves on my DS2072 from a tiny microphone I have.  Do I need to build a circuit to do this?  If so, how?
Thanks,
Alan
Offline dc101
Re: How can I see sound on an oscilloscope with a microphone?
« Reply #1 on: March 30, 2014, 11:46:29 pm »
Try running the mic to the input of your computer and then the speaker output to the input of your scope.  Otherwise you could get by with a simple audio amplifier circuit.
Offline nctnico
« Reply #2 on: March 30, 2014, 11:59:09 pm »
Chances are it is an electret microphone. All that needs is a bias of around 3k Ohm to 5V. The sensitivity will depend on the value of the resistor but 3k is a good start.
Offline EEVblog
« Reply #4 on: March 31, 2014, 12:08:31 am »
You don't need anything more than your scope probe:
Offline GreyWoolfe
  • NW0LF
« Reply #5 on: March 31, 2014, 01:15:18 am »
I tested a Kenwood MC-50 desk microphone just using my Hantek DSO.
Offline mcinque
  • I know that I know nothing
« Reply #6 on: March 31, 2014, 11:15:11 am »
I guess an electret should work but since AFAIK its sensitivity is not linear you may get wrong readings: I suggest you to use a good dynamic microphone without any other use of circuitry. You should be able to read the AC variations caused by the sound that makes vibrate the microphone's membrane
« Reply #7 on: March 31, 2014, 02:35:16 pm »
I did get the electret to work with the circuit I posted, but I'm not so sure how well.
There are a lot of dynamic microphones at amazon for around $10 or so.  They look like they have a 1/4" jack on them.  Will this need an amplifier circuit to work?
Offline ju1ce
« Reply #8 on: March 31, 2014, 03:05:34 pm »
If seeing sound is all you want to do, you can also connect a speaker to your oscilloscope and shout at it.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #9 on: April 01, 2014, 03:05:15 am »
set the DS2072 to mV range and set the sound volume into the mic to the maxed you can, done!
Offline zapta
« Reply #10 on: April 04, 2014, 02:48:41 pm »
If your probes are x10 don't use them, connects wires directly to the scope.
Offline MikeGyver
« Reply #11 on: April 05, 2014, 04:34:25 am »
Ground the pin of the electret mic with the little ground path to the case, pull up other pin to 5-12volts or whatever with a 4.7-47k resistor, and put a cap to that node, other side of cap is audio out. 3 components to use an electret condenser mic, doesn't get much easier than that.
