Does anyone have an example of some pictures that show static charge distribution along insulators?
The idea being similar to showing current in a ground plane (as shown by mikes electric stuff), that is in this case to connect a surface electrostatic voltmeter to a light source, so the brightness of the bulb changes based on charge magnitude (and diff color for opposite polarity), and then to use a long exposure.
(or just take measurements at every point and simulate it with software zzz)
this is related to my other thread
https://www.eevblog.com/forum/projects/measuring-static-charge-with-an-electrometer-19267/msg658822/#msg658822But anyway, pictures of actual professionally done mappings would be cool to see.
