The mini Rogowski coil current probes that can fit between the leads of a TO-220 transistor that are made by CWT and also re-branded by Tek and Agilent always seemed so nifty. Unlike the DC current probes with a thin film hall effect sensor, there is no "special sauce" in these current probes that is hard to make. I got fed up with waiting for a low cost clone to appear so I made my own. This was also my first project trying out the low cost PCBA services.
The rogowski coil produces a voltage proportional to the dI/dt and requires an integrator, and the integrator low frequency cutoff plays a dominant role in determining system noise. This probe is optimized to be useful for typical SMPS frequencies while being able to resolve relatively low currents. A huge portion of the design effort went to the actual coil design: both figuring out a nice mechanical solution and the optimal wire, coil form, and heat shrink combination. If you want to fit between the leads of a TO-220 package there is a hard cutoff of < 1.7mm OD. I tried about 20 different heat shrink types, 4 types of wire, and 3 different coil forms before coming up with the ideal combination.
The full project details are on the project repo, but the specs are: 800Hz - 25MHz, 0.1V/A, 6mA RMS noise.
https://github.com/westonb/rogowski-relief The dv/dt rejection of the coil decent. If I tape the coil to a floating heatsink that slews ~20V/ns and 250V there is a ~ 1A blip on the output, and there is improvement if you try to keep the coil a bit shielded. The most recent work I have done on the project relates is on reducing the interference from wifi/LTE cellular that gets rectified by the inputs of the opamp.
Verifying the amplifier was my first time trying out noise simulation in LTSpice, its pretty cool to see that the LTSpice model matches pretty closely with my measurements.
The design uses a non-inverting integrator, which is advantageous because you can roll the cable capacitance into the integrating capacitance, and a servo high-pass architecture with a second op-amp.
The servo high-pass is advantageous because it rolls off the low frequency, reducing low frequency gain and nulling any DC offset.
At some point I had a vague goal of making these to sell, but all the regulatory requirements are a pain to deal with and the coil takes a lot of labor to assemble the coil. So the whole project is just open source on github instead.
