Author Topic: dual base transistor?  (Read 516 times)
Offline coppercone2Topic starter
« on: November 22, 2024, 08:07:49 am »
I found a dual gate MOS transistor. Ok, it looks interesting to play with one day.
Dual gate transistors look to be mainly RF type devices.
But I wondered if it has a counterpart, i.e. a Dual base transistor.  :-//
the symbol exists on german wikipedia
« Last Edit: November 22, 2024, 08:12:26 am by coppercone2 »
Offline IconicPCB
Re: dual base transistor?
« Reply #1 on: November 22, 2024, 08:33:22 am »
Dual gate fet is actually a cascode kind of structure where the lower transistor drain drives the source of the upper device typically used in RF work. The BJT equivalent is similarly structured such that the lower discrete transistor drives the emitter of the upper transistor.Upper transistor operates in common base configuration and presents a low impedance load to the lower device minimising  deleterious effects of Miller capacitance. I have not come across a dual base cascode single package device.
Offline guenthert
« Reply #2 on: November 22, 2024, 08:46:29 am »
Well not quite a dual-base transistor and won't match the given symbol, but there are (or were) unijunction transistors (e.g. 2N2646).
Online Kleinstein
« Reply #3 on: November 22, 2024, 08:49:33 am »
I also have not seen cascode connected dual BJTs as the equivalent to a dual gate MOSFETs. There are JFET+BJT hybrids however.
Inside ICs there are also dual emitter/collector transistors, with the emitter or collector split to different parts. These were used in some TTL gates and are used for current mirrors. I have not seem them as discrete parts.
« Reply #4 on: November 22, 2024, 08:59:58 am »
I thought they were like this.
« Last Edit: November 22, 2024, 09:06:03 am by coppercone2 »
Online voltsandjolts
« Reply #5 on: November 22, 2024, 09:22:59 am »
Note the internal connection between gate 1 and gate 2 in your second picture, which just makes a standard fet, with improved characteristics.
« Reply #6 on: November 22, 2024, 09:46:11 am »
Oh I thought it was more clear, but I think they have isolated ones? Or are all the isolated ones cascode structure?
I only found it interesting because I thought they had separate drivers
« Last Edit: November 22, 2024, 09:50:24 am by coppercone2 »
