Author Topic: "MLCCs ... do not require any voltage derating"  (Read 7362 times)
Offline 741Topic starter
    • Circuit & PCB Design (small PCB quantities OK)
« on: May 15, 2020, 11:22:49 am »
Here is TDK's paper https://product.tdk.com/en/contact/faq/20_mlcc_voltage_strength.pdf
That seems useful information, I think 6.3V is therefore fine for 5V, and that makes some cost difference for 10uF units.
Online wraper
  • Country: lv
Re: "MLCCs ... do not require any voltage derating"
« Reply #1 on: May 15, 2020, 11:25:32 am »
You should derate voltage for MLCC because of huge capacitance drop under voltage, not because of reliability issues. Likely there will be 10-25% of capacitance left for 10uF cap when used under rated voltage.
Offline Rerouter
« Reply #2 on: May 15, 2020, 11:29:34 am »
To make things more complex, you really do need to look at the datasheet due to how the capacitance vs voltage curves change for every different series and manufacturer, sometime a 10V MLCC can be better than a 25V MLCC of similar size, because they then use a different method to allow for the higher voltage rating, which in turn makes the voltage curve tank much harder.
« Reply #3 on: May 15, 2020, 11:58:03 am »
That is a very good point, applying to many MLCC types.
For problematic ('ferroelectric') dielectrics at given 'rating' like 6.3V, I was wondering how much 'product range' variation there can be - do the dielectric, voltage rating, capacitance and size/shape all affect this issue? The reply just now by "Rerouter" shows it is indeed down to the individual datasheet.
I'm looking at a Multicomp (Farnell/CPC) branded item, MCCA000593, 'X5R', CPC code CA08032.
The 10uF capacitor is at the output of an MCP1623 switcher, giving 5V output. I would imagine it will spend most of the time at about 5V, so at least any voltage dependence is a fixed factor. There are no plots for voltage dependence I can see on the DS.
I am committed to 0805 for now - maybe I should have assumed a 1206 size, that might be better "voltage rating for voltage rating"?
Offline Rerouter
« Reply #4 on: May 15, 2020, 12:12:10 pm »
Larger sizes with the same voltage and capacitance are "usually" better, however it comes down to exactly what dielectric material they use,
Sadly there are multiple flavors of materials that still meet the specifications for X7R, which they use in different capacitance vs voltage groupings, so you may find the 0805 and the 1206 actually still use the same material, just with less layers. yet drop from a 10V 0805 to a 6.3V 1206 and suddenly its much better because they used a different composition to make up that 1206 X7R dielectric, as the density was now low enough that it made more sense to use a different material,
Yes this stuff drives me mad, because they go out of there way to make it almost impossible to do parametric comparisons across manufacturers, even different series from the same manufacturer!
Online ejeffrey
« Reply #5 on: May 15, 2020, 02:43:56 pm »
Yeah it's totally bonkers.  Capacitance at 80% voltage rating should be a standard datasheet parameter.  Even better would be a digikey style search engine that lets you filter by capacitance at target voltage.  A bare minimum would be for digikeys datasheet section to link to the manufacturers ratings for that specific part number (where available) that has all the curves including c vs v.  Instead they usually only link to the series datasheet that is basically useless.
The following users thanked this post: thm_w, tooki
Online Vovk_Z
  • Country: ua
« Reply #6 on: May 15, 2020, 05:03:59 pm »
I have my small experience with 1V...20 V circuits: I tried several 1206 size X7R 50V and 1..10 micro-Farad caps and had some stability problems (in oscillator AGC circuits and DC-DC power supply) (0805 is no good for uF at all). Then I moved to 1210 size (4.7 uF x 50 V caps) - and everything started to be fine.
I mean 4.7 uF 50 V 1210 X7R caps worked for me as good as film caps.
For example, 1210 4.7 uF 50 V cap worked clearly better than 10 uF 50 V 1206 cap.
« Last Edit: May 15, 2020, 05:16:46 pm by Vovk_Z »
Offline Siwastaja
« Reply #7 on: May 15, 2020, 05:28:46 pm »
General process for high-capacitance (X7R, X5R, similar) power networks:
1. Figure out the actual capacitance you really need. If you don't really know or are replicating a circuit in application note, note that if they say "2.2uF ceramic", it really means some typical part, which will have between 0.4 .. 1 uF of actual capacitance.
2. Look at the products with
* DC bias capacitance curve available
* Rated voltage at least your bus voltage, but no extra margin needed. You should include higher ratings, though! You may find a better deal by "derating" voltage, but contrary to common misbelief, this always isn't the case.
* Rated capacitance starting from about 2x what you need (no sense at looking anything lower; everything which is sensible regarding cost and PCB area, loses at least 50%), to maybe up to 8-10 times what you need (some lose 90% of C; nothing wrong with that if you still get what you need).
This way you may end up with possibly 5-10 part numbers.
3. Make an Excel table:
Part number
Price
Actual capacitance at your voltage (from the curves)
Price / capacitance
4. Pick the lowest $/uF.
Consider possibilities such as paralleling multiple sizes. Paralleling four 0805 capacitors gives you a smaller inductance than one 1210 capacitor which can't be placed as closely than the closest 0805.
If you want to work with assumptions instead of data, pick a size that is two notches higher than the smallest case size which carries the C and V ratings you are after, then you have good chances it doesn't lose 90% of C under bias, like the smallest size miracle on the market does. For example, a 1uF 0805 X7R part will do quite fine, and it's likely some 0.5uF at 10V, often completely regardless whether the voltage rating is 10V or 50V! A 1uF 0402 part would be down to 0.1uF at 10V, though, and it could be still rated for 16V, which just means it's completely safe to do so.
No DC bias curve available? Tough luck, you can assume they are fairly similar to the competitor parts with the same specs (most importantly case size, secondarily, dielectric type, then C, V ratings), unless you have a critical application requiring paperwork.
TDK provides data for their capacitors in a nice interactive website, so it's often easiest to just use their parts.
« Last Edit: May 15, 2020, 05:36:34 pm by Siwastaja »
The following users thanked this post: doktor pyta, Vovk_Z
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #8 on: May 15, 2020, 06:54:53 pm »
There are few generalizations with respect to capacitance at voltage.
The best, but still weak, is physical size.  A large cap is more likely to be filled with electrodes, and so a smaller value (say 10nF) will have them spaced more widely and bear a higher voltage cutoff*, and a larger value (say 10uF) will be low.
*The voltage where capacitance drops by, say, 30%.
Certainly, a very large value, at voltage, needs a large volume.  There must be some physical limit to energy density.  Of course, there's nothing stopping them from putting like two electrodes inside a tall ass 1210 and calling it a "0.1uF 50V" when it runs out of piss at a mere 10V.
I have seen little correlation between rated voltage, and voltage cutoff.  I've seen parts by Taiyo Yuden and others that are 90% gone at rated voltage and cutoff at say 20% of the rating.  I've seen Samsung and Murata parts which are rated for 6.3V but are still going at 10V (though the published curves rarely extend beyond rated voltage, YMMV).
You'll also often see families of parts, where it seems to be the absolutely identical component, just bearing different voltage ratings.  Presumably you are paying a little premium for quality -- hopefully, they were tested to that voltage, but yeah as far as I know they may very well be utterly identical parts.  No difference in C(V), obviously -- might as well get the cheaper (lower voltage) option that still suits the application (C at V and V rated >= V needed).
KEMET gives curves but I find them dubious as they're all the same copy-pasted piecewise curve -- someone did shitty analysis there, but they still stick with it.  Maybe the data are representative, I'm not sure.  AVX is a big name but does not publish curves.  No design-in from me.  Most Vishay brands, same thing.  Samsung seems to be hit and miss: maybe 50% of their parts link to a characteristic sheet, maybe 50% of those have a link that doesn't 404, and maybe 25-50% of those have a curve that is acceptable for my application.  TDK you have to download SEAT.  KEMET and Murata have their databases accessible online.
The only solution is digging through lots of datasheets, and often not datasheets but char sheets, web tools, and downloadable databases.  It's tedious, selecting one capacitor takes tens of minutes.
A final note about type: don't be tempted by high density types: Z5U, Y5P, even X5R is on the marginal side.  All of them age terribly (C drops with log(time since soldering)) and have steep C(V) or C(T) curves.  X7R is the least objectionable, or numbers nearby like X8R and such (look up ceramic capacitor codes) also perform well, and are just produced less.
If you don't need large values, or can afford a pricey cap, and do need high stability, C0G is essentially an ideal capacitor formulation!  They also outperform [non-electret*] type II dielectrics at high voltages (100s V), worthy for dense energy storage.
*There's a technology where the type II dielectric is poled either by applying voltage and temperature during manufacture, or in use (I don't understand how spontaneous poling works, but apparently it's a thing??).  Cera-Link is an example brand.  By building in a trapped electric field, the high-C characteristic of the dielectric can be shifted towards a usefully high voltage, e.g. centered on 300V or so.  This massively increases the energy storage!
Good luck,
« Last Edit: May 15, 2020, 07:02:11 pm by T3sl4co1l »
Seven Transistor Labs, LLC
The following users thanked this post: doktor pyta, nfmax, Siwastaja, uer166, I wanted a rude username, Vovk_Z
Offline ConKbot
« Reply #9 on: May 15, 2020, 08:03:18 pm »
Not sure if its new or not, but you can also browse TDK online.
https://product.tdk.com/en/search/capacitor/ceramic/mlcc/characteristic/
If you scroll down to the DC-Bias characteristics, you can put in an operating voltage, and optionally a desired capacitance range too.
Also, +1 on the Y/Z dielectric caps. Ive seen a Kemet (I think) rep ragging on how bad they are in a video of an official company educational presentation on ceramic caps. You know its bad when the rep unabashedly talks negatively about them rather than trying to upsell whatever redeeming characteristics they may have.
Offline thm_w
  • Non-expert
« Reply #10 on: May 15, 2020, 10:21:21 pm »
Interesting, can be quite useful. Specifically for a boost converter I was looking at, it had a short high voltage spike which dissipates quickly.
I could never get any ceramic capacitors to fail on my ~60v power supply, now I know why, its not even close.
Offline Someone
    • send complaints here
« Reply #11 on: May 15, 2020, 11:15:54 pm »
I've seen enough volume production to conclude that derating does improve product reliability/lifetime. The policies in place at large companies come to similar figures from their production histories. Voltage x2 is a good starting point for most capacitors, if lifespan is a concern.
Many ceramic capacitors are guaranteed for a 2x/2.5x/3x voltage withstand, not sure if it is 100% tested but a single short constant current test would quickly bin them for capacitance and voltage rating.
Offline Someone
« Reply #12 on: May 15, 2020, 11:17:03 pm »
When they do fail it can be spectacular. Lots of energy in a tiny volume = explosion and/or flames.
Offline T3sl4co1l
« Reply #13 on: May 15, 2020, 11:32:29 pm »
AFAIK, ceramic failures are more commonly due to cracking, which can be poor soldering profile, improper handling, strong vibration, etc.  One product (I work on from time to time), the customer has had consistent problems with a few large capacitors around the edge of the board; probably they're getting stressed during assembly?  (Fortunately, they just announced a re-design campaign!  I can get my hands all over this finally, instead of the small maintenance fixes I've done over the years.)
It's often standard in automotive to use caps in series, so that your 12V, 30A+ circuit doesn't unload through a puny cracked capacitor.  There are also types with floating electrode design (effectively two caps in series, in one part), longer terminations (so the crack propagating from the solder joint tends not to cross the electrode stack), and soft terminations (so the crack propagates through the metallization, avoiding the chip).
Yeah, the capacitor itself discharging can deliver enough energy to locally melt things, leaving a conductive path; even if not, a mere crack at the kinds of distances scales we're talking here (microns) can break down easily.  And if you've got any kind of DC or AC power behind it, well...
The following users thanked this post: nfmax
Online wraper
  • Country: lv
« Reply #14 on: May 15, 2020, 11:36:18 pm »
More like dead short and nothing spectacular happens. As it's dead short, not a lot of power to dissipate. And ceramic does not burn. If something will burn spectacularly due to this short, it will probably be something else.
Offline Someone
« Reply #15 on: May 16, 2020, 03:29:44 am »
Yes, cracking is far more commonplace than wear out/age related failure. But I've seen the evidence of capacitors with otherwise similarly excellent mechanical handling/use fail at elevated rates with increasing voltage. Ceramic caps are so reliable on the wear-out end of the curve you need to have an otherwise very reliable design and/or large volumes to notice.
Cracks usually show up as an open or short, not always caught by a functional test. But I bet there would also be partial shorts with elevated leakage or not-quite short.
Play with some capacitors to failure, they aren't a sharp transition straight to 0 ohms. Likely some thermal runaway positive-feedback effects too. An example of abusing a ceramic cap:
https://www.eevblog.com/forum/projects/mlcc-discharge-curves/msg735041/#msg735041
That was done with the expectation that it could detonate, and suitable physical precautions were in place despite the supply being power limited.
Offline tggzzz
« Reply #16 on: May 16, 2020, 06:54:22 am »
Multicomp is a Farnell invention - they buy whatever they can that meets their spec. Hence you might need to re-test each batch you buy.
Offline Siwastaja
« Reply #17 on: May 16, 2020, 09:35:56 am »
I have had a 1210 X7R ceramic capacitor (Murata) fail as a few ohms short, not blowing the fuse, and actually glow bright orange, converting everything in vicinity to smoke. I guess surface tension kept it in place even if the solder melted.
I happened to be nearby and cut power in some 5-10 seconds. Eventually it would have evaporated the PCB traces, but the results are not nice.
Yes, the reason was me failing at correctly soldering the parts. Take the appnotes about cracking seriously. Not only board flex, but also soldering.
Voltage derating isn't an answer, though. Although you could see a small reliability improvement by luck, the chances are, you see a decrease in reliability if you have to choose a larger package because of the voltage derating policy; larger parts crack more easily. The only real solution is to perfect the mechanical design and assembly (soldering) and handling processes so that the cracks simply don't happen. Use soft termination parts as an extra layer of safety, then.
« Last Edit: May 16, 2020, 09:38:33 am by Siwastaja »
Online wraper
  • Country: lv
« Reply #18 on: May 16, 2020, 02:10:59 pm »
It's not that simple. Parts which push spec boundaries for the size and have a lot of very thin layers are way less reliable.
Offline Siwastaja
« Reply #19 on: May 16, 2020, 02:19:46 pm »
Yes, the point exactly was that it's not that simple.
Soft terminations certainly help. Following the guidelines for stress-free mounting definitely helps.
Everything else, not that simple; too many factors. Voltage derating for example - no guarantee of increased reliability. Layers are thicker, but cracking is still dangerous: a shear of, say, 100um, still shorts them out.
In my example (glowing bright orange), voltage rating was 50V and applied voltage was 10V. No mechanical stresses, just soldering process violations.
« Last Edit: May 16, 2020, 02:21:53 pm by Siwastaja »
Online wraper
  • Country: lv
« Reply #20 on: May 16, 2020, 02:39:05 pm »
Yes, you should avid soldering SMT MLCC with soldering iron as much as possible. If you need to fix reflow issues or repair something, it's better to use hot air when possible.
Offline Siwastaja
« Reply #21 on: May 16, 2020, 02:45:23 pm »
Yes, to recap, avoid connecting MLCCs directly to planes, use thermal reliefs instead during PCB design.
If soldering with iron, preheat the board and quickly solder the pads. Avoid touching the ceramic body with the iron, or applying too much force with the tweezers. The common mistake here is that you need to apply heat for prolonged time because the solder doesn't flow into the board which is still too cold, but you are applying the heat to the MLCC as well all this time.
« Last Edit: May 16, 2020, 02:47:00 pm by Siwastaja »
