Hello There!
I'm reading this forum for quite a while now, and this time, i decided to register, as I come across something I cannot understand, at all!
So, basically, i designed a Nixie Tube clock, and one of the main switch for the 170VDC was an IRF730, it did a great job except it isn't really logic level gate operation.
The MOSFET never fully turned on and the Rds was quite a problem, as the MOSFET keep heating.
Pretty sure of what I was doing, i decided to replace the IRF730 by an IRL640A, 200V, 18A, 0.18ohm@5V Rds.
As the pinout is the same, it was supposed to be plug and play...
Except it wasn't, at all... Nothing worked, the tubes were off, flickering at best. Probing the gate, it was stuck somewhere at its threshold voltage (±2V), the poor ATMega328p trying to supply 5V in vain.
Desoldering and testing it with an RCL meter, it was fried... appearing as 2 resistances (short between G-S and D-S).
Then i went full retard but I still don't understand how I managed to fried my 10 MOSFETS :
I hooked them up, one by one, to my DP832, 30VDC, 0.5A max on channel 1, between D and S, channel 3 at 5V, negative terminal on the source, and positive on the gate... I FRIED THEM ALL, WTF ?
(they didn't fried at 10VDC, it seems to fry as soon as channel 1 exceeded Vgs max, even if it wasn't hooked onto the gate).
I don't understand what i did wrong, and i HATE that!
both channels were hooked with the negative terminal to the source, there is now way the gate voltage exceeded 20V, or am I an idiot ?
Thanks a lot and see ya!
Cheers.
