Hi Guys
I need help identifying a 5pin socket on a PCB in a heatpump so I can find a matching connector for it. It looks to have a pitch of 2mm
I suspect it is a molex or similar but can't find any that look the same.
I had some 5pin JST PH connectors laying around which are the right length but too wide to fit in.
I was wonderign if someone recognises this connected (See attached image)
