Author Topic: Modern day 723 and 78xx for new design  (Read 5295 times)
Offline tkamiyaTopic starter
« on: January 25, 2019, 04:46:05 pm »
In old days, if one was making power supply, he/she used 723 or 78xx.  But both of those series are quite dated.  What's the modern day equivalent?
I need a low noise/ripple 24V 3A power supply.
Online Wolfgang
    • Electronic Projects for Fun
Re: Modern day 723 and 78xx for new design
« Reply #1 on: January 25, 2019, 06:21:42 pm »
I had the same question. All the "good" new ICs are for lower voltages. If you find a *real* replacement for a 723, please tell me ! (but dont forget, I need 40V input, 150mA, ...).
Offline SiliconWizard
« Reply #2 on: January 25, 2019, 06:59:43 pm »
Quite a few. Just to mention LT/AD: https://www.analog.com/en/parametricsearch/11536
Eg:
https://www.analog.com/en/products/lt1084.html
https://www.analog.com/en/products/adp7142.html
Now for those saying they are too pricy, go have a look at Alpha&Omega stuff. ;D
Online Wolfgang
« Reply #3 on: January 25, 2019, 07:12:50 pm »
... not even close.
Where are the following 723 features:
- reference can be filtered
- long term drift spec
- settable current limit
- configurable compensation
- flexilibility to be used a spositive, negative, floating, ... regulator.
Why people still work with the 723 is:
- extremely flexible
- stable
- cheap like hell. 10€Cents in quantities, all "replacements" are some €.
Offline iMo
  • Country: va
« Reply #4 on: January 25, 2019, 07:16:48 pm »
723 works as a switcher too..
Online Wolfgang
« Reply #5 on: January 25, 2019, 07:18:42 pm »
... thats correct. I have never seen it in the wild, however. A lot of (older) units use TL494 or SGxxx type ICs.
Offline iMo
  • Country: va
« Reply #6 on: January 25, 2019, 07:46:47 pm »
This is a 723 switcher from a car charger (cigarette lighter adapter 14V->5V).
The following users thanked this post: Wolfgang
Offline Giuss
« Reply #7 on: January 25, 2019, 09:04:49 pm »
I think that the 723 is still a very good chip
Online Wolfgang
« Reply #9 on: January 25, 2019, 09:42:22 pm »
LDP 7142 and LT1084 are like LM317.  Not as cheap as 78xx and not as robust as 723.  Hum....  hard to imagine not much happened in 30+ years...
Offline schmitt trigger
  • Country: mx
« Reply #10 on: January 25, 2019, 10:13:18 pm »
WOW. A Harris semiconductor CA723. Nice vintage find.
Of course, a metal can uA723 would be an even better vintage part.
Online Wolfgang
« Reply #11 on: January 25, 2019, 10:17:23 pm »
The oldest ones I have are Harris military chips in CERDIP from 1986.
Photo here:
https://electronicprojectsforfun.wordpress.com/2018/09/18/not-all-lm723s-are-born-equal/
Offline Hiemal
« Reply #12 on: January 25, 2019, 10:31:45 pm »
I got one!
http://ww1.microchip.com/downloads/en/DeviceDoc/mic5156.pdf
These are quite pricey, but they have the advantage of being able to use N-channel mosfets. The 5158 version even has a built in charge pump to ensure proper gate drive, something that I feel is pretty unique.
Offline coromonadalix
« Reply #13 on: January 25, 2019, 11:02:32 pm »
Here is a very nice and well done project by velleman
The K7200 kit  0-30v 0-10 amps power supply
The 723 can make good psu's, it's still in production
https://www.velleman.eu/downloads/0/manual_k7200.pdf
« Last Edit: January 25, 2019, 11:04:11 pm by coromonadalix »
« Reply #14 on: January 25, 2019, 11:27:47 pm »
I think I'm going to use LM317.  Load regulation 0.05% and ripple is 0.5%.  That's about 1.n mV at 24V.  Not bad for simple circuit.  7824 on the other hand is order of magnitude worse.
Offline iMo
  • Country: va
« Reply #15 on: January 25, 2019, 11:30:31 pm »
What is the IC3 in the Velleman's kit?
Offline iMo
  • Country: va
« Reply #16 on: January 25, 2019, 11:41:50 pm »
You will not get 3A out of an 317..
Offline markce
« Reply #17 on: January 26, 2019, 12:12:17 am »
Another 723
The following users thanked this post: iMo
« Reply #18 on: January 26, 2019, 04:06:25 am »
yep  dual 723 regulators
one for voltage and one for current
Offline DaJMasta
    • medpants.com
« Reply #19 on: January 26, 2019, 05:34:45 am »
Sure you can, you just feed it the minimum voltage above dropout and put on a decent heatsink ;)
Offline mariush
« Reply #20 on: January 26, 2019, 06:29:53 am »
No, most 317 regulators are advertised as 1.5A regulators and they have a "typical" current limit at around 2-2.2A ... maybe you can use an extra transistor to get 3A but just with the regulator alone, 3A ain't happening.
Offline iMo
  • Country: va
« Reply #21 on: January 26, 2019, 07:47:10 am »
The 317 recommended max Iout is 1.5A. For 3A you need an extra pass transistor over it (plus some basic overcurrent protection), or to run 2x317 in parallel (with some care}, or to use the LM338 (5A version).
« Last Edit: January 26, 2019, 07:56:11 am by imo »
Online David Hess
  • DavidH
« Reply #22 on: January 26, 2019, 10:51:05 pm »
Nothing has replaced the 723 and it is still in production.  The 317 is a general improved replacement for the 78xx series.  Improvements over the 317 and 78xx series include the LT1086 which is available in fixed and variable versions.
There have been other improved 78xx and 317 parts over the years but none caught on as much as the LT1086 and similar 3-pin parts.
Online Wolfgang
« Reply #23 on: January 26, 2019, 11:02:29 pm »
People have tried to replace the 723 with better chips like the SG3532,  ...
they had thermal protection, lower voltage references, better current limiting, ...
but they could not match the 10c per chip, so nobody bought them and the vanished from the market.
Offline battmyrne216
« Reply #24 on: January 27, 2019, 06:00:51 am »
nice example from an elenco power supply that used the 723. Edit: actually this schematic only uses the lm317. but the elenco I had happened to use the 723. Ive found its version schematic before but now im gonna have to find it.
« Last Edit: January 27, 2019, 06:03:59 am by battmyrne216 »
