Author Topic: Modifying a 1KHz Low Distortion Audio Range Oscillator  (Read 903 times)
Offline enut11Topic starter
  • Love building/modifying/restoring test equipment
« on: January 29, 2022, 09:52:59 am »
This audio signal generator design is sold on eBay as a 1KHz Low Distortion Audio Range Oscillator. Preferred power supply is +/-15v although it will work down to +/-9v or less. At 15vDC it outputs up to 7vRMS. A 2K pot on the output is all that is required for variable amplitude.
It can be purchased as a kit or fully assembled. Performance is excellent with distortion <<0.01% and if fed from a regulated supply provides a very stable amplitude.
an electronics nut from wayback...
Re: Modifying a 1KHz Low Distortion Audio Range Oscillator
« Reply #1 on: January 29, 2022, 10:02:39 am »
My application needs a variable frequency up to about 20KHz so I was playing around with changing the values of R6/R7 (ganged 10K pot) and C1/C2.
Frequencies lower than 1KHz were easy to achieve but the high frequency limit seems to be about 6KHz after which the signal becomes unstable in both frequency and amplitude.
I suspect this may have something to do with the amplitude control circuitry around TL071 but I do not understand how this part of the circuit works.
Any suggestions on how to proceed?
Offline Renate
« Reply #2 on: January 29, 2022, 02:27:38 pm »
I think you have to decrease C3/C4 proportionally to increase speed of response and retain stability.
The following users thanked this post: enut11
« Reply #3 on: January 29, 2022, 08:17:23 pm »
thanks @Renate. Changing C4 to 0.047uF and C1/C2 to 0.0047uF allowed me to push the frequency up to 12KHz before instability. Lower frequencies were not affected by this mod.
« Last Edit: January 30, 2022, 12:08:42 am by enut11 »
Offline Vovk_Z
  • Country: ua
« Reply #4 on: January 29, 2022, 11:50:59 pm »
R1, R2, R3 values influence stability too. So you may play with them.
