Author Topic: ON RC time delay to drive a transistor  (Read 729 times)
Offline Nikos A.Topic starter
  • Country: cy
« on: July 25, 2023, 08:45:12 pm »
Hi guys,
I want to create an ON RC time delay circuit to drive the gate of a transistor. I will use the 2N3904 NPN. With the transistor, I want to drive a DC/DC converter module.
https://www.robotaki.com/dc-dc-step-up-circuit-module-3v-to-5v-1a
My problem is that the capacitor does not charge above 0.75 - 0.8V and the transistor does not conduct. When disconnecting the ground from the transistor, the delay works fine and the capacitor charge in t=RC. What do I miss?
Note: I tried to replace the dc/dc converter with an LED and the LED turns on based on the delay (however the voltage across the capacitor remains 0.75-0.8V)
This is my circuit
Offline Benta
Re: ON RC time delay to drive a transistor
« Reply #1 on: July 25, 2023, 09:22:27 pm »
The circuit works exactly as it should.
That it doesn't do what you expect is a different thing.
For example:
You list a 1 A DC/DC module. The 2N3904 will not carry that much current.
The 2N3904 is a BJT. It needs base (not gate!) current. 100 kohm is far too high.
In short: this concept will just not work. Look for a module with an "Enable" input instead.
« Last Edit: July 26, 2023, 12:20:37 am by Benta »
  • Country: cy
« Reply #2 on: July 25, 2023, 10:02:58 pm »
Thank you for your response Benta,
The maximum current I intend to draw from the boost converter is 50mA.
However, the capacitor won't charge above 0.8V with the current RC network even without the boost converter connected.
« Last Edit: July 25, 2023, 10:05:27 pm by Nikos A. »
Offline Benta
« Reply #3 on: July 25, 2023, 10:27:17 pm »
You're right, it won't. It behaves exactly as designed.
  • Country: cy
« Reply #4 on: July 25, 2023, 10:39:50 pm »
Could you explain why?
Offline PCB.Wiz
« Reply #5 on: July 25, 2023, 10:51:17 pm »
Of course, it is clamped by the base. 8)
If you really want to use a NPN part, then work back from the 50mA. Ballpark might be 1v change and 1mA base current, to saturate reasonably at 50mA.
That puts C as ~3mF or 3000uF, and R as ~ 2k2
Or, you might want to change to a MOSFET - that has no base current limitation, so you can use higher R and smaller C.
You need a lower threshold gate mosfet that will drive 50mA from 3V, so a FDV303N or similar part, that gives < 1 Ohm with VGS 2.7 or 2.5V
  • Country: cy
« Reply #6 on: July 25, 2023, 11:08:04 pm »
Thank you a lot!! I will try both solutions!! Do you think the 555 timer is more suitable for this application?
Offline PCB.Wiz
« Reply #7 on: July 26, 2023, 12:22:26 am »
Not really, if you want more control and low current / voltage  operation, maybe look at Voltage Monitors with user programmable delays.
Parts like NCV308SN180 have a 1.8V threshold, and a cap sets the delay (~ 390nF for 3s) until the pin goes high (which then turns on a MOSFET)
