Author Topic: Ground Planes  (Read 891 times)
Offline Nikos A.Topic starter
  • Country: cy
Ground Planes
« on: June 26, 2019, 05:51:03 pm »
Hi everyone,
This a PCB that I am trying to complete (the picture that you see is the first layer).. There are separated ground planes as I am using isolated converter.
The ground plane on the bottom layer is suggest to be as the top layer (seperated) and place some vias between them to achieve solid ground plane?
