I am trying to figure out a way to get an understanding of the world of the voltage regulator products that are sold in the market. I am an electronic engineer myself (FPGA, RTL, Verification side) and am trying to learn PCB design nowadays.
I know the basic idea of voltage regulator, it is a device that is designed to maintain output voltage at a fixed value inspite of change in the load. There are basically two types, linear and switched. The switched type has higher efficiency. I do not fully understand their internal working. The special features that I know of are short circuit protection i.e shut down the output voltage supply if the current load goes above a certain level and overheat protection i.e shut down the voltage supply if the temperature of the voltage regulator goes above a certain level. The voltage regulators will need some external components to be connected so they can work. This is the gist of what I know.
Now, what I am trying to do is, find a resource that rather than explain what a voltage regulator is, actually explains what voltage regulator types and features exist in the market. In my search I either find very basic information material or very specialized. I just need something that says, ok here in the market we have products of XYZ categories and these have XYZ features and this is how to choose the right voltage regulator for your application for the 1000s of products that exist. Are you aware of a resource that can explain this?
