Normally an audio output stage has a temperature compensated DC Vbe applied to the bases of the BJT output transistors. As they heat up the applied Vbe is lowered to maintain more or less the same quiescent collector current. What would happen if instead we applied a small but constant *current* to the bases and let the the Vbe consequently look after itself. If this would work there would presumably be no need for thermal contact to the output transistors. Surely someone must have tried this.
