Home made laser power meters are typically made with a modest size Peltier Thermoelectric cooler ran in reverse as a calorimeter. Graciously heat sink one side, and either glue on a thin piece of black anodized aluminum or paint with a high carbon, high temperature flat black engine paint (Krylon high temp grill paint or engine paint is 98% carbon black in the US) . If you can machine graphite, a thin graphite panel works well, but is highly reflective if your not careful with the surface finish. "Black Velvet" paint from Nextel / 3M is the old, preferred, improvised coating, but it costs a fortune.
I've had good luck when I was a college kid with fine carbon black and clear nail polish or potassium silicate solution (floor sealer, hardware store) as the binder. These days I use a carbon nanotube mix for blackening sensors. However these days I also have a considerable collection of professional LPMs that outperform the home made gear.
Run it into a variable gain op-amp, with a gain from 10-100 or so and read it with a volt meter.
Real thermopile power meters use a custom absorber material, and an array of specially designed ultra thin Peltier elements.
Home calibration is done with a thin, flat coil of resistance wire of known characteristics (usually around 30-40 ohms) and a bench power supply. No where near as accurate as a commercial model, but should get you +/- 5% across the visible range if your black surface has a flat adsorption spectrum.
Be aware, that the quality difference between a home made one and a commercial unit is considerable. The commercial unit will compensate for a lot of technical factors, have an anticipator circuit to speed the reading. It will be able to take much, much more beam energy.
Even on commercial units, we spread the beam out across the sensor with a lens some times to avoid surface damage.
As I often tell laser hobbyists, nothing comes close to a commercial laser power meter when doing comparison measurements or when tuning the laser.
PS< Most of the older Coherent OEM LPM heads on Ebay output .40 mV per Watt.
Steve
