Yesterday afternoon I built a test circuit using a NTD5806NT4G because I happen to have a bunch of them from another project.
Something weird is happening.
For the test I'm just running into an electronic load set to 10A CC and only using a 15V supply because that's all I have that can supply 10A.
The MOSFET is failing intermittently when I switch off and on the 15V supply. I've gone through 6 MOSFETs so far and still haven't been able to determine exactly why it's failing. Triggering the oscilloscope on the power supply I never see the voltage on the gate exceed 10V above the supply voltage so I'm obviously missing something. I ran out of time yesterday so will get back to it on Monday.
The MOSFETs are always failing short (approx 1 Ohm) drain to source and about 100 Ohms to the gate.
My first thought was that the turn on/off time was too long, so I tried feeding a 10Hz signal into the control FET. I ran it for over a minute and the MOSFET was slightly warm, but nothing I'd be concerned about. It immediately failed when I cycled the 15V supply.
Now I'm going to be wondering about this mystery all weekend.
