Author Topic: Mostly manual PCB cad recommendation please  (Read 1269 times)
Offline tkamiyaTopic starter
« on: February 06, 2020, 10:55:00 pm »
Are there any PCB cad software that lets me manually place rounds and vias and hand-route traces?  I only need simple 2 layer boards.  I do not need any auto-routing capability or capturing circuit diagrams.  My ideal candidate would be 2 layer board, 10cm x 10cm or larger, grid line on display, manual placement of rounds and specify size of holes, then manually route traces, and create ground pours.  The end result should be a gerber file that I can send to manufacturing.
PLEASE - no argument as to why and such-and-such method is better.  I have my reasons which I am not willing to share in public forums.  (I'm not trying to be rude, please do understand)
Online ve7xen
    • VE7XEN Blog
Re: Mostly manual PCB cad recommendation please
« Reply #1 on: February 06, 2020, 10:56:43 pm »
I think most ECAD software should be able to handle this. You might need to turn off some automatic ERC checks / push and shove and such but it shouldn't be that hard. It's not like I've tried, of course, but I believe this should be doable in KiCad if you peruse the options and disable the stuff that prevents you from joining dissimilar nets.
73 de VE7XEN
He/Him
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #2 on: February 06, 2020, 11:03:00 pm »
I'm not sure if KiCad will pour copper fills that are not connected to any net.
Online ejeffrey
« Reply #3 on: February 06, 2020, 11:09:47 pm »
In my experience most eda cad tools can do this but it is more trouble than it is worth.  Using AutoCAD or some other generic 2D cad tool might be easier.  I gave up and usually just create a dummy schematic.
Offline markce
« Reply #4 on: February 06, 2020, 11:20:28 pm »
I use the Sprint-Layout tool from Abacom for this.
It is cheap and very easy to use. Good for small projects and hobby use.
You can download a trial copy from: https://www.electronic-software-shop.com/
« Last Edit: February 06, 2020, 11:31:21 pm by markce »
Online ve7xen
    • VE7XEN Blog
« Reply #5 on: February 06, 2020, 11:30:16 pm »
It can, there's a no-net option in the pour settings.
It actually seems like you don't really need to disable anything or do much fiddling around to make it work as OP is requesting. Without a netlist loaded it pretty much seems to let you do whatever you want.
73 de VE7XEN
He/Him
The following users thanked this post: thinkfat
Online MarkF
« Reply #6 on: February 07, 2020, 12:43:48 am »
I have probably laid out half of my PCBs without a schematic.
Even some fairly complex boards.
I agree that most if not all CAD tools should be able to do this.
My software of choice has been DipTrace for many years.
Their free version is limited to 2 layers and 300 pins.  (Not PCB size).
Quick and easy to learn.
