If your PCB fabricator supports internal routing (most (all?) of the inexpensive ones don't, at least not officially), then you could route a slot in one board that the other slots into. Careful alignment of copper pads on the edge of each will allow you to solder them together, preferably on both sides, which should be pretty sturdy if your slot is sized to a close fit.
