Author Topic: Mounting modules on pcb  (Read 1185 times)
Offline m98Topic starter
« on: July 28, 2020, 09:33:42 am »
for a product prototype, I need to mount a few modules with castellated hole contacts onto one main pcb. Since the modules are quite expensive, I don't want to solder them onto the prototype pcbs. And as they're relatively large and don't have continuous contact rows on each side, they won't fit into any standard LCC socket. Are there any surface mount spring contacts that would provide a snug fit?
Offline tooki
Re: Mounting modules on pcb
« Reply #1 on: July 28, 2020, 10:03:35 am »
I would solder them using low-temperature tin-bismuth solder. Then you can easily desolder them for later reuse, without risking desoldering any other components. Use a cheap hot air rework tool.
Beyond that, I’d peruse the Mill-Max and Harwin catalogs to see if there are any spring loaded pins that would work.
Online ledtester
« Reply #3 on: July 28, 2020, 02:54:53 pm »
This might work if you can get the right pitch:
https://www.aliexpress.com/item/4000282372452.html
Title: 5pcs Spring Compression Contact 2.0 mm Pitch 2 3 4 5 6 7 8 Pin Male Surface Mount PCB modular Connector battery Straight
1035028-0
Online ledtester
« Reply #4 on: July 29, 2020, 01:10:44 am »
ok, one last idea...
1035506-0
