Hi guys, quick question with regards to replacing failed axial electrolytic capacitors in test equipment with newer, radial ones:
All specs being equal (capacitance, voltage rating etc...)
how would you mount the replacement radial capacitor?
1: mount the capacitor centrally and have equal length + and - leads going to the original PCB holes
2: mount the capacitors + lead as close to the PCB hole as possible and have a long - lead to the other hole
3: mount the capacitors - lead as close to the PCB hole as possible and have a long + lead to the other hole
I was leaning towards option 2, with the - lead running across the board, this would reduce the possibility of the + lead touching anything (lead would obviously be insulated either way) but i wasn't sure if having an extra long ground lead would increase susceptibility to interference or anything? increase the inductance of the capacitor and increase ripple current?
The capacitors that need replacing are in the power supply section of an old 'scope if that has any influence on it?
Look forward to getting some replys. I'm fairly sure that theres not going to be too much in it, other than from a best practices point of view, and no long + leads running across the board!
