Is there a way to check MOV integrity some how? And some how extrapolate the data to a curve that shows some kind of information about what you can expect from them?
Is there a way to do it with specialized equipment, like leakage in a megger? I have seen MOV holders that are built like fuse holders, so you can replace your MOV as a periodic maintenance procedure if you are interested in high reliability, like proactively replacing fuses on a maintenance schedule. I have never seen a fuse tester before though, only replacement to fall within some kind of SOG.
Is there a way to do it in circuit while powered? Leakage current monitoring? Some kind of high frequency measurement (like using a periodic RF signal to test their integrity).. I would like to boil it down to some kind of simple analog circuit if possible.
For instance you can do this with peltier modules (kinda), measure their impedance, to see the deviation from normal, and a useful pass/fail system can be developed this way. Usually done at like 100Hz. I guess you can monitor the IV characteristic too if you prefer.
Same goes for fuses, I can't imagine what kind of information you would get from them though, maybe a raise in resistance? Can some kind of change of alloy stress/crystal phase change be detected using RF/Microwave and sensitive equipment for electrical measurement? I assume you might be able to check the fuse structure change on a x-ray crystalography machine but that's really crazy. It's really hard for me to imagine a DC impedance test to provide useful information ,but I thought maybe some kind of microwave test might show something (really far out I know), maybe something related to skin effect due to different alloy composition? I assume it work hardens and a different crystalline structure of whatever the fuse is made of will show up due to fast cooling on the surface. Maybe this manifests itself as a nonlinear effect at some terribly high frequency?
I also thought some kind of porosity test can be conducted on the fuse wire to maybe see microcracks or something on the surface related to many cycles but again thats impractical and crazy unless its some expensive fuse.
I mean data that can generate a useful reliability curve.
Maybe tempco gets weird when they are degraded?
This provides some insight
http://www.digikey.fi/en/pdf/l/littelfuse/lf-varistortestingBut I am interested to know if there are better methods. You can't do the voltage drop method in circuit because it requires current limiting, unless you switch in a resistor/DCsource and disable protection for the duration of the test. Since they are DC devices a AC/RF test could be used with the appropriate filter networks, even if they are energized to high voltage.
Do you think with a MOV you can measure a high frequency voltage drop by feeding it a high voltage high frequency signal that's current limited, and block the supply by putting a inductor or ferrite on the MOV to Line/DC (connect the MOV through a LPF)? Where the test signal frequency is >> then the line voltage so you can properly direct it with filter impedance?
It would effect the performance of the MOV but you can use a different circuit element to handle HF HV stuff maybe that is not widdled down by the LF, like connect another MOV through a beefy HPF after the MOV that has to deal with the 60Hz. And then monitor that mov with a low frequency that does not go through the HPF. The reason for this would be because line impedance is unstable usually, so you would need to either stabilize line impedance or use filters to set up impedance so you are not measuring a rando asshat impedance leakage.
Don't know if you can beat the response of a GDTMOV combo with filtered MOV though. Maybe. Also on lower voltage MOV.
