Ok, I got that part, so while sh is low, the charge is constantly being transferred?
So if I were to stop transferring the image half the way for a moment, I would get a second exposition?
Actually, it suits for my project to have a long exposition time.
Would you please just study the datasheet page by page, slowly. Please!
While SH is low, sensor is integrating charge, on rising edge, charge from pixels is transfered to pipeline, on falling edge pixels are charged and disconected from pipeline. Pipeline and pixels are not the same thing ! You are reading data from pipeline (analog shift register), not dirrectly from pixels and there is no way you can read directly from pixels. Charge is being integrated on pixels when shutter is low no matter if you are reading data out or not. And you must have BT and RS signals still running - STILL !
State where SH signal is high more than just few microsecs is not mentioned nowhere and hence I strongly reccomend you to keep it this way !
Also, you MUST read whole video frame including last invalid pixels. MUST ! Some sensors even might stop to operate properly, if you break this rule.
And what is your aplication for this sensor ?
Spectrometer is my guess - I can tell you, that range of integration time you will be using is somewhere in 1 to 100ms, not more (if not, you have some bug in optical setup).
There is something called dark output signal and dynamic range of sensor. With higher integration times, dynamic range becomes smaller and smaller to the point, where it is just basically useless.
Anyhow, I suggest black tape is probably not going to work. the package is glass and light will still get in from the sides. You need to get yourself a light-tight box of some sort while you are experimenting, even if you do manage to significantly reduce your integration time.
Not true - it is cerdip with quartz glass window glued IN (not ON) top part, so actually if you manage to cover sensor all over the top side, there are no leaks. What is bad idea is the black tape - sensor is sensitive to some 1300-odd nanometers and what is "black" in VIS spectra might not be so opaque in infrared, right ? I was not suggesting aluminium tape just by mistake
