Incidentally, every so often you see higher voltage diodes advertising similar methods (electron bombardment, transition metal (usually Pt) doping) to control carrier lifetime. At very light doping and over a gently graded junction, this gives reasonable performance (t_rr ~ 30ns) for 600V diodes, at modest expense to Vf (say, Vf = 1-3V at rated current).
And it seems to not work so well at higher voltages (~200ns for 1200V, and I think I've seen 2-4us "fast recovery" hockeypucks in the 3-6kV range, which is about as high as Si can possibly go), which makes sense as carrier lifetime depends on doping, and with lighter doping, yeah.
Which, by the way, is a good reason why you may find RF or switching or power types stink at low currents -- hFE drops off quickly. Some power transistors this is explicit -- Darlingtons usually, with internal B-E resistors. This doesn't break Ebers-Moll or whatever, so you still get the transconductance you expect, but the base conductance can be higher than you might expect.
