Author Topic: Color Organ Design  (Read 2366 times)
Offline aep9690Topic starter
Color Organ Design
« on: September 11, 2012, 03:26:22 am »
I am designing a color organ.  The idea is that I would plug a headphone plug into it and then the board would filter it into bass, mid and high range which would then use darlington transistors to drive a couple high power 1W LEDs.  I simulated it using pspice and it worked they way I wanted, but simulations can only go so far.  I attached the schematic I have and was hoping I could get some feedback before I go into PCB layout.
